Whether you’re a homeowner or a renter, home security should always be a priority. However, making modifications to a home you own can be simple, but it’s not so straightforward when you pay rent. Any changes to the rental unit can put your deposit in jeopardy.
So, is there a way to protect your home without making significant, permanent changes to a rental unit? With options like Arlo, the answer is yes. DIY security systems can be easily installed without risking your deposit. Plus, you can effectively build a budget home security system without breaking the bank. Let’s learn how to protect your rented home.
Wait, do renters get their deposit back?
Yes, security deposits are refundable. Renters are legally entitled to get their deposit back at the end of their lease. That is, unless there’s a valid reason for the landlord to retain the money. Your lease agreement should outline the conditions under which the deposit will be returned. If not, consider negotiating the rental agreement—and the deposit amount—before moving in.
Avoid making any changes or causing damage to your rental home, except for the usual wear and tear from living in it. This is why a DIY-install security system like Arlo’s is a great option for renters. Plus, if you move out, you can take your security devices with you.
What can cause you to lose your security deposit?
According to the legal aid organization Michigan Legal Help, possible reasons to retain the deposit include unpaid rent, outstanding utility bills, or leaving the home damaged beyond normal wear and tear. Whether your changes count as improvements or damages can be a bit unclear. It’s up to the landlord to decide.
The property manager or landlord can use the deposit to cover the remaining debts or apartment repair costs. After covering these costs, you are entitled to receive the remaining money from your deposit. We recommend asking your landlord for copies of receipts for the actual cost of repairs.
If you are indeed entitled to receive your deposit back (or part of it) and your former landlord refuses, you can file a claim and sue them in a small claims court.
Can I drill holes in the walls of a rented home?
In most cases, the answer is yes. However, there’s a simple “but”: You need to restore the walls to their prior condition before moving out. Check with your landlord before getting your power drill ready. To fix wall holes after drilling, simply fill them with spackle or putty, let it dry completely, sand it smooth and paint over it to match the wall.
Before moving in, consider snapping some photos of your unit to document its condition, including any existing holes or damage. Having this photographic evidence can be really helpful in proving that you’re not responsible for any pre-existing issues when the time comes to move out.
