1. First, choose a smart home platform.
Since not every smart device is compatible with each other, first you need to choose a smart home platform. There are many different options, but the most popular ones include Google Home, Amazon Alexa, Apple HomeKit, and Samsung SmartThings.
The smart home platform you invest in will determine the devices that can be integrated into your home. For example, don’t expect your Google Nest Mini speaker to operate with light bulbs designed for Amazon Alexa. Fortunately, your Arlo smart security devices are compatible with most smart home platforms.
2. Pick your first smart home device.
Once you’ve chosen your smart home ecosystem, it’s time to pick your first smart device. As you scroll through your options, remember to look for compatibility with your chosen platform. Most products come with a label that reads “Designed for Google Home” or “Compatible with Amazon Alexa.”
So, what do you want to automate first? There’s a crazy amount of options including smart light bulbs, window blinds, smart thermostats, fridges, home entertainment systems, garage doors, locks, TVs, and more. You can even automate your smart security camera, like the Arlo Essential Security Camera (3rd Gen) which is compatible with Google Home and Amazon Alexa.
The best part? It’s your choice, and there are plenty of options that will work well for your needs. Select a compatible smart device, install the app to configure your schedule, and make it yours.
3. Invest in a great wireless network router.
Most smart devices rely on your Wi-Fi network, making good internet connectivity crucial. Here’s a great tip for you: Invest in a high-quality router. Not only will this provide a better overall network experience, but it will also future-proof your home automation ecosystem. While you might not encounter issues with two or three connected devices, imagine having 50 or more smart products running on a 10-year-old router.
4. Make old tech smart with a smart plug.
Instead of replacing all your devices, consider smart plugs. What is a smart plug, and what are the benefits of a smart plug? A smart plug lets you integrate older appliances into your smart home. Just plug in lamps, fans, or TVs, and control them remotely. It’s eco-friendly, budget-wise, and offers energy management.
5. Install a smart security camera and a video doorbell.
Your Arlo smart home security camera system can be integrated into your home security ecosystem. Use it to keep an eye on your home and receive alerts when strangers are getting close. Options like the Arlo Essential Security Camera (3rd Gen) come with Motion Detection, Color Night Vision, and a wide 130° Field of View. Whether it’s intended for protecting your home or simply monitoring your pet, installing a smart security camera is a great decision.
A video doorbell, on the other hand, will provide front porch protection. Options like the Arlo Video Doorbell feature models in HD or 2K video resolution for a lifelike image. With 2-Way Audio, you can remotely listen and speak to visitors. Pair it with a smart lock, and you can even open the door to family and friends from a distance.
