How To Catch Thieves With High Resolution Security Cameras
A high resolution camera might just be what your security setup needs.
Read Now
Best Security Setups
Share:
Picture this: You just got a confirmation email that your package was delivered. But, wait, it’s missing from your front porch. You decide to check your security camera footage. Aha! You spot a thief approaching your property and taking your package. “I got you now!” you say, only to feel your excitement turn into utter disappointment. As you zoom in on the burglar’s face, you’re met with a blurry, unrecognizable mess of pixels. (Goodbye for good, new espresso machine.)
If this happens to you and your packages actually get stolen, here’s what you should do. Unfortunately, recovering from some other types of theft is not so simple. Being able to identify intruders could be crucial, and that’s where high resolution security cameras really shine. Let’s explore how to catch thieves in high resolution with Arlo by your side.
How do high resolution security cameras help catch thieves?
What is security camera resolution, and why should you invest in a high resolution security camera? In short, resolution refers to the number of pixels in an image or video. High resolution cameras can record video in High Definition or better. This means they have significantly more pixels than older digital cameras, and can capture much more detailed footage to protect your home.
Why should you buy a high resolution security camera? Simply put, more pixels mean higher resolution, resulting in clearer and more detailed security footage. This can make all the difference between identifying a thief and forever wondering who’s brewing stolen coffee with your stolen espresso machine.
With a 4K camera or high resolution security camera, your footage will be filled with additional, valuable details for catching thieves. For instance, look at this intruder wanna-be on an Arlo security camera:
What details should I seek out in security camera footage?
When reviewing security camera footage, it’s vital to keep an eye on several important details. With a high resolution camera, you gain access to a wealth of new information that is valuable to provide evidence of a break-in or trespassers for police or your insurance company. When evaluating your footage, keep an eye out for:
Facial features and specific characteristics like body build.
Clothing and attire.
Tattoos and other distinctive markings, like scars.
Vehicle features, like the license plate number, make, model, and color.
Other people or witnesses who might have relevant information.
Capture incriminating audio recordings thanks to 2-Way audio capabilities.
What video features should I look for in a new security camera?
When browsing new security cameras, you should keep an eye out for reliable features including resolution, color night vision, and motion detection. With so many features, it can be challenging to remember the essentials for the best video quality. When choosing a new security camera, here are the top picks you should keep in mind:
Resolution. First, you should look for a camera with high image quality. While most cameras capture HD or 2K video, others offer stunning 4K resolution, like the Arlo Ultra 2 Security Camera. With a higher resolution, you’ll have the ability to zoom in further on your security footage, allowing for more detailed analysis.
Night vision range. Your camera should be able to capture high quality video even in the poorest lighting conditions. Look for high resolution night vision security cameras, like the mentioned Arlo Ultra 2 Camera. This model features Color Night Vision to record clear footage even in complete darkness.
Wide field of view. A wider lens captures more of your property, providing a broader view of your surroundings. Most cameras feature a 130° Field of View. Options like the Arlo Ultra 2 take it to the next level with an ultra-wide 180° Field of View.
Motion detection. A security camera system with motion detection will start recording the second it senses movement. You’ll receive instant notifications on your phone as soon as the camera detects any intruder. With cameras like the Arlo Ultra 2, you can even set the Integrated Siren to sound automatically when motion is detected.
What are the best high resolution security cameras out there?
Nowadays, there’s no reason to settle for low-resolution security cameras. You should aim for a minimum of 1080p. However, as you’ve probably gathered by now, more pixels are always better. Here’s our lineup of high resolution cameras.
Options like the Arlo 2nd Gen Essential Wireless Outdoor Security Camera offer excellent value for your money. You can choose between HD video or 2K video capture. It also includes features like an Integrated Spotlight, clear 2-Way Audio, and Color Night Vision. In our Arlo vs. Ring comparison, it stands out as one of the best budget-friendly cameras available. If you’re looking to level up, consider cameras like the Arlo Pro 5S 2K Wireless Security Camera. This model boasts 2K HDR video capture, 12x digital zoom, an Integrated Spotlight, and more.
For security on the go, untethered from your Wi-Fi connection, choose cameras like the Arlo Go 2 LTE Camera. This high resolution security camera has 4G LTE connectivity, letting you record 1080p Full HD footage wherever you go. It also features a microSD slot for local storage recording.
For the ultimate high resolution protection, consider options like the previously mentioned Arlo Ultra 2 Security Camera. With 4K HDR video, Color Night Vision, and an ultra-wide 180° Field of View, you’ll see every single detail in your footage.
With the included Arlo Secure Subscription Plan trial, you get extra features like 24/7 Professional Monitoring and One Tap Emergency Response. Plus, with cellular and battery backup, it ensures your security remains active even during power outages and Wi-Fi disruptions. Why not take advantage of the free trial while you’re away?
Cover your bases with Arlo Secure 24/7.
Arlo’s security cameras are easy to install, feature smart home integration, and live monitoring from your smartphone. Ranging from HD to 4K video, indoor and outdoor cameras like Arlo security cameras provide the resolution you need to catch even the most elusive of thieves. Even better? With a subscription plan like Arlo Secure, you can view, share, and save 30 days of video storage and event recordings from anywhere. Just remember: The higher the resolution, the greater your peace of mind.
