You just installed your new Arlo Essential Indoor Security Camera (3rd Gen) in your living room. You feel safer than ever, but something feels off — and you’re not quite sure why. Is it because your new security camera is in plain sight, making it easy for anybody to disable? Or perhaps you like how it looks, but it just doesn’t fit your home decor style.
Whatever the reason, hiding your camera can offer many advantages. Here’s how to do it in the best way possible. Spoiler: It’s easier than you think, but you may have to get creative.
How to hide a security camera indoors.
Outdoors, you want to make your security cameras visible to deter any potential intruders. Options like the Go 2 LTE/Wi-Fi Security Camera might discourage thieves when placed directly near an entryway or key entry point. However, you want indoor cameras like the Arlo Essential Indoor Security Camera (3rd Gen) to go unnoticed. Consider the following tips and you’ll have them hidden in no time.
1. Choose a strategic placement with a wide field of view.
Before going all out to conceal your camera, first, you need to find a good spot for it. You may think you’ve found the perfect hiding place, only to later realize that the camera has a pretty disappointing view.
Try to place the camera above eye-level, where it has a clear view of the room. Key areas like the front door or windows should always be in frame. Finally, make sure there’s nothing blocking the camera lens.
If you have an advanced home security system for your home or business, don’t worry about light conditions. Options like the Arlo Essential Indoor Security Camera (3rd Gen) have night vision, so they’re able to record video even in the dark. Plus, a 130° viewing angle makes sure you capture it all.
2. Use your home decor and furniture.
There’s no need to go all super spy with fake smoke detectors or two-way mirrors. Start with what’s already in your house. Household items like potted plants are great for hiding cameras. Use their leaves and branches for camouflage.
Bookshelves and cabinets are great, too. Place the camera between books, behind ornaments, or in dark corners. (Even that ugly router may turn out to be your best camera cover.)
If the goal is to avoid drawing attention to your camera, sticking to everyday decor is the best way to go.
