On the menu? Your recipe to watch your restaurant from anywhere with Arlo.
Read Now
Best Security Setups
Share:
Protecting your business is essential. That’s why investing in wireless security cameras for restaurants is a wise decision. With the right security cameras, you can monitor every area from the kitchen to the bar — and proactively prevent potential threats.
But with so many options on the market, which surveillance system should you choose? Instead of picking a traditional security system, we recommend opting for a DIY business security camera system. Here’s how you can do it.
Why should I choose a DIY security system for my restaurant?
Building your own security system offers several benefits, with the primary advantage being its budget-friendly nature. Plus, you have the flexibility to customize it to meet your specific requirements.
For instance, do you want to keep an eye on the cash register? Simply install a wired security camera, like the Arlo 2nd Gen Essential Indoor Camera. Is there a back door you would like to monitor? Add an alarm system, like the Arlo Home Security System.
Here are other reasons why a DIY security system could be the best option for your restaurant:
Cost-effective:DIY systems are more affordable than traditional security systems.
Easy installation: They are easy to install, with compact equipment that doesn’t require a dedicated back room.
No installation fees: You can install security cameras yourself, cutting down installation fees.
Flexibility:Cameras are easy to mount, allowing you to relocate them as needed.
Low maintenance: You won’t need to deal with DVRs, network video recorders, or tapes, reducing maintenance and potential risks.
Remote viewing:You can access a live feed from your smartphone, enabling remote viewing from anywhere.
Cloud storage: You can store security footage in the cloud with subscriptions like Arlo Secure, starting at just $4.99 per month.
Options like Arlo are a smart and modern take on video security for your restaurant or bar. Arlo provides a complete system of high resolution cameras, alarm systems, and more. While Arlo primarily caters to homeowners, their security solutions are equally effective in protecting your restaurant or bar.
What are the benefits of having a restaurant security camera system?
Why should you invest in a restaurant security camera system? In short, a security camera system allows you to monitor your restaurant, keep an eye on clients and employees, and prevent potential dangers. Here are seven benefits of investing in a DIY security camera system for your restaurant or bar.
1. Have every angle covered, from the dining area to the parking lot.
With the right security cameras, you’ll have eyes everywhere, even when you aren’t around. Choose cameras that cover your specific needs. For indoor protection, you can explore options like the Arlo 2nd Gen Essential Wired Indoor Camera. This model is available in either a 1080p or 2K Video Resolution camera, and has Light Vision Motion Detection, and an Automated Privacy Shield.
You should always cover broader, high-traffic areas with a camera (or three) including the cash register, restaurant entryway, back doors, as well as the kitchen and back driveway. Opt for 4K cameras that provide more detailed quality video. Options like the Arlo Ultra 2 record video in 4K with HDR, with an ultra-wide 180° viewing angle. In areas where Wi-Fi isn’t available, you can choose an LTE-enabled camera.
Options like the Arlo Go 2 offer 4G LTE connectivity. This camera ensures HD resolution video quality even during network or power outages. Plus, in the event that neither Wi-Fi nor mobile data is available, the Arlo Go 2 has a slot for a MicroSD card to record locally too.
2. Keep your employees safe and secure.
A security system allows you to keep an eye on not only your clients, but also your employees. Your security setup lets you know if your employees are working in a safe environment. Plus, a reliable security system allows managers and business owners to have footage of any incidents that can be used as evidence for any insurance claims.
Install a camera pointing at your cash register, letting you know who has access to it. If there’s an off-limits room, like a management office, consider mounting an alarm system like the Arlo Home Security System. It comes with All-in-One Sensors that monitor door and window openings, motion, water leak detection, light changes, and more.
3. Keep an eye on dark corners.
From the dumpster in the alley to your equipment in the loading dock. Night vision cameras make it easy to monitor every corner of your restaurant. Consider solutions like the Arlo 2nd Gen Essential Security Camera. This model features Color Night Vision, Motion Detection, and an Integrated Spotlight
Don’t forget to protect your restaurant after hours. Reliable cameras with color night vision are essential to deter criminals in the dark and capture any attempted break-ins at night. For the protection of alleyways, driveways, and other expansive areas, you can use wire-free floodlights. Well-illuminated areas also help prevent accidents. Options like the Pro 3 Wireless Floodlight Camera feature an integrated 2K security camera. This floodlight is also weather-resistant for year-round security.
4. Knockout fights and violence before they happen.
Having a security camera is likely to deter crimes from happening. It discourages potential thieves from invading your property. But, it could also make your customers think twice before starting a confrontation or “taking it outside.” You could also consider letting everyone know that your restaurant is protected with an Arlo Security Sign.
5. Take inventory of every order.
With a security camera system, you’ll know exactly what is delivered to your business during every shift. You’ll also know when and where it happens. This ensures you get the right items in the right quantities, and lets you identify any mix-ups or potential losses.
6. Be prepared for additional dangers.
Modern alarm systems can detect various potential threats, including fires. Options like the Arlo Home Security System go beyond that. It features All-in-One Sensors that allow you to monitor eight different dangers like smoke, temperature changes, water leaks, and more.
For instance, you can install a sensor in the kitchen to receive alerts about potential fires. Place them in areas prone to water damage, like pantries or storage rooms. If there’s a water leak or flooding, you’ll receive immediate notifications to prevent damage to stored items. You could even use the All-in-One Sensors to monitor temperature in wine cellars. If there’s an unexpected temperature change, you can protect your wine collection.
7. Save on your electricity bill with battery-powered cameras.
Wireless cameras operate on battery power, activating recording when they detect motion. This extends their battery life. In the long term, it could also save on your electricity bill compared to traditional hardwired security systems. Want to take it a step further? Use Solar Panel Chargers to keep your cameras charged with clean, solar energy.
Keep your restaurant protected with Arlo.
Arlo understands small businesses. You may not have an IT team or a franchise budget, but that doesn’t mean you can protect your local business from day one. Arlo security cameras and alarm systems make it easy and affordable to keep your business secured around the clock.
