3. Get rid of potential break-in points and hiding spots.
Take a proactive approach by walking the perimeter of your property and identifying any potential weaknesses in your security. A good idea is to try to think like a trespasser and search for potential access points and hiding spots.
For instance, check for loose planks in your fence, which home invaders might remove to enter your premises. Or consider the presence of a tree that could potentially give them easy access to a window.
Keep your fences in good condition and prune bushes so nobody can hide behind them. Also, try to keep your yard tidy and free of large objects, like ladders and boxes. You’ll want to have a good view of the surroundings.
A recent study indicated that many burglaries are not committed using information gathered in advance, but rather when opportunities arise. Minimizing break-in points and hiding spots means completely shutting down these opportunities.
4. Consider installing a smart door lock.
From time to time, we all can forget to close the front door or leave the keys in the lock. Smart locks eliminate this possibility of human error. You can program them to automatically lock the doors or send a notification when one is left open. They also work with passcodes or a mobile app, so there’s no need to worry about hiding a spare key. Don’t forget to change your locks if you’ve recently moved in for a fresh and secure start in your new home.
Plus, smart locks are much harder to brute force than traditional door locks. Consider pairing it with a video doorbell, like the Arlo 2nd Generation Video Doorbell, for the ultimate front door protection. This model features a wide 180° viewing angle, an Integrated Siren, and motion detection.
5. Install bright lighting around your property.
A well-illuminated perimeter is crucial when preventing a home invasion. Lights eliminate dark corners, shadowy areas, and blind spots where potential intruders could hide. Plus, the increased visibility allows you to see any suspicious activity and take proper action.
Bright lighting is also a specially strong deterrent to potential criminals. Well-lit areas make them feel exposed and vulnerable, discouraging them from attempting to break in.
Consider installing motion-activated lights in key areas, such as entry points and pathways. These lights instantly turn on when motion is detected, alerting you to any movement and surprising anyone approaching your property. Remember that some cameras double as motion-sensing lights. For all-in-one security, upgrade your outdoor lighting by replacing it with options like the Arlo Pro 3 Wireless Floodlight Camera. It has a powerful 2K security camera built into its bright LED floodlight.
