If you’ve recently moved into a new home or apartment, chances are you’ve browsed online for a home security system. If you’re overwhelmed by the options out there, you’re definitely not alone. Both Arlo and Ring offer comprehensive ecosystems with sensors, video doorbells, accessories, security cameras, and optional subscription plans.
With so many product options from both companies, choosing the best one for your needs can be challenging. What is the difference between Ring Doorbell vs. Arlo Video Doorbell? How do you know which cameras are right for you? Let’s compare these two industry leaders, and help you build the best home security system for you.
Arlo vs. Ring: What’s the difference?
Arlo and Ring are both popular brands in the home security space, known for their DIY home security systems. Founded in 2014, Arlo focused primarily on wireless home security cameras, but has since expanded to offer a comprehensive range of security devices, like floodlights, indoor cameras with a privacy shield, video doorbells, and a home security system. Ring has provided a complete security ecosystem from when it was founded in 2013.
1. Do Arlo and Ring security systems need a hub?
You don’t need a hub to use most Arlo or Ring security devices. Hubs are only needed for Ring’s alarm systems (which are included in their offered bundles) and some specific cameras.
2. Which companies own Arlo and Ring?
Both are American companies. Arlo was previously a brand by Netgear, but now is an independent public company. Ring is owned by Amazon.
3. Do Arlo and Ring security systems offer Smart Home integration?
Most Ring devices can be connected to and controlled from Alexa-enabled devices, like an Amazon Echo Show. Keep in mind that this feature requires a subscription fee. Most Arlo devices are compatible with Amazon Alexa, Apple HomeKit, Google Assistant, If This Then That (IFTTT), and Samsung SmartThings—without a subscription. You can easily add Arlo to Apple Home and use Arlo products with the SmartThings app.
4. Do Arlo and Ring offer subscription plans?
Both companies offer optional subscription plans designed to expand the functionality of their security devices. While you get live feed with every Arlo and Ring camera, a subscription with a storage plan is necessary for accessing cloud video history. The Arlo Secure subscription, for example, includes cloud storage for high-quality video recordings for up to 30 days.
Both the Arlo Secure Plan and the Ring Protect Plan offer additional features like smart notifications and AI object detection. For instance, Arlo cameras can identify people, vehicles, animals, objects, and even fire. Ring cameras offer free customization of motion-detection zones, while Arlo Activity Zones are exclusively included in their subscription. Both companies also offer optional 24/7 professional monitoring.
