Your Parking Lot Security Camera Guide? Right Here.
Worry-free parking lots with Arlo security cameras.
Read Now
Best Security Setups
Share:
Research shows that violent crime is more likely to occur in parking lots than in other facilities. This is mainly because parking lots comprise a large area with low levels of activity, tons of hiding spots, and unrestricted access.
As a property manager, you’re probably already considering how to improve security in your parking lot for everyone’s safety. The good news? Protecting a parking lot isn’t as challenging as you might imagine. You can use this guide as a starting point to protect your parking facilities and prevent unfortunate incidents.
What are the benefits of parking lot security cameras?
A parking lot security camera system allows you to monitor access, detect suspicious activities, enhance customer and employee safety, deter potential criminals, and document information in case of an incident. For example, you can capture license plate numbers and facial features for identification and prosecution purposes.
Additionally, a security camera system can assist you in filing a claim with your insurance company by providing proof of an accident or theft. All of them are compelling reasons to invest in your parking lot’s security. Here’s how you can do it.
How to secure a parking lot in 7 simple steps.
Curious how to safeguard a parking lot? Consider installing security cameras, improving lighting conditions, inspecting the lot for potential entry points, training your staff, and installing motion sensors. All these measures will help prevent accidents and deter potential intruders. Just like when picking the best security cameras for the workplace, it’s helpful to assess and understand your parking lot security needs, and then choose your security measures accordingly.
1. First, monitor your parking lot with security cameras.
A video surveillance system should be your first step to enhance a parking lot’s security. Many different surveillance camera systems are available to choose from. Options include wired cameras, wireless cameras, IP cameras, Pan-Tilt-Zoom (PTZ) cameras, and more.
What are the best security cameras for parking lots? Well, the best camera for a parking lot is the one tailored to your unique security needs. Parking lots for businesses and apartment buildings tend to be large, so wired cameras may not be the most suitable choice. Instead, wireless parking lot security cameras are recommended.
Aim for a high-quality, secure camera system that is ideal for parking lot surveillance. Keep in mind that most parking lots are outdoors, so a weatherproof security camera system is recommended. All of Arlo’s outdoor cameras are weather-resistant to withstand the elements and can operate in temperatures between -4° F (-20° C) and 113° F (45° C).
Options like Arlo security cameras are easy to install, offer real-time monitoring, and come with many features such as motion detection. You can opt for cameras like the Arlo Ultra Security Camera (3rd Gen), a robust 4K camera with HDR video and Color Night Vision, ideal for monitoring large square footage areas. Featuring high-resolution video, ultra-wide 180° Field of View, and 12X digital zoom, you can easily capture more details and thoroughly review your security footage in high definition.
For a more budget-friendly approach, you can consider alternatives like the Arlo Essential Security Camera (3rd Gen). Available in 2K or HD, this camera offers a 130° Field of View, an Integrated Spotlight, 2-Way Audio, and Color Night Vision for 24/7 coverage. It provides convenient, high-quality protection starting at just $69.99. Camera installation is simple with the included mount.
Do you live in an area that’s prone to power outages? You can even plug the wireless camera into a Solar Panel Charger to keep the battery charged, making it perfect for outdoor parking lots or jobsites. The Arlo 2nd Gen Essential is also a great garage security camera.
If you’re concerned about Wi-Fi coverage, consider exploring 4G LTE cameras. Options like the Arlo Go 2 are ideal for those who require 24/7 security in areas without power or Wi-Fi access. With 4G LTE connectivity and a long-lasting battery, you can monitor even the farthest corner of your parking lot.
Keep in mind that you can further enhance every Arlo camera with the Arlo Secure subscription plan. Arlo Secure offers 30-Day Cloud Storage for your video footage, AI video analytics for Smart Object Detection, and even theft replacement.
2. Track movement with a motion-activated floodlight.
Indoor parking lots often lack adequate lighting, which makes them hard to monitor. Outdoor parking lots aren’t always well-lit at night. Installing security lighting is your best option for countering any criminal activity and preventing potential accidents from occurring.
Consider installing a motion-activated floodlight. This not only deters potential criminals but also assists drivers when parking. You can explore options like the Arlo Pro 3 Floodlight Camera. This model integrates a powerful 2K security camera with a bright LED floodlight for comprehensive security. The Arlo Pro 3 Floodlight Camera can adjust up to 3000 lumens* of brightness, providing light for expansive areas.
3. Make sure criminals know your parking lot is protected.
Most security systems include a sticker or a sign you can mount. If so, consider mounting them to let everyone know your parking lot is protected. Criminals will think twice before entering your parking lot and business. Consider options like the Arlo Security Sign.
Also, remember that visible security cameras are more likely to deter potential criminals. Keep this in mind when properly positioning them. Aim to install security cameras in strategic spots, prioritizing Field of View and visibility.
4. Regularly inspect the parking lot.
By regularly assessing security vulnerabilities, you can better protect your parking lot and deter potential intruders. Walk the perimeter of your parking lot and identify any potential weaknesses in your security. Think like a potential intruder and search for access points and hiding spots.
For instance, check for any gaps or breaches in fencing or barriers that could allow unauthorized entry. Look for any structures that could provide cover for suspicious activity. Keep your perimeter fencing in good condition. Make sure bushes are trimmed to prevent anyone from hiding behind them. Additionally, keep your parking lot free of large objects that could obscure visibility, such as unused equipment or debris.
5. Train your staff with safety and security protocols.
Ensure your staff is well-trained in safety and security protocols. Conduct regular training sessions to educate them on identifying and responding to potential security threats effectively. Teach them how to recognize suspicious behavior and how to handle various security incidents professionally and efficiently.
By empowering your staff with the necessary skills, you can enhance the overall safety of your parking lot. Adequate training will provide a sense of security for both clients and employees.
6. Install motion sensors in entryways to detect intruders after hours.
Monitoring access can be challenging, especially in businesses and apartment buildings with parking lots, which often feature multiple entrances. An alarm system enables you to monitor entry points such as doors, windows, and garage doors. This is especially helpful after operating hours. Options like the Arlo Home Security System go beyond that, adding the ability to detect and monitor eight different threats. For instance, the included All-in-One Sensors are capable of detecting water leaks, temperature changes, motion, and listening to smoke and CO alarms.
To further enhance security, consider pairing the Arlo Home Security System with an Arlo Secure subscription for 24/7 Professional Monitoring. If you’re wondering if Pro Monitoring is worth it, the answer is yes. This service ensures that Safety Agents are always on hand to contact you or the authorities if there’s a breach, even when you’re not available.
7. Install emergency call boxes.
Install emergency call boxes strategically throughout the premises. An emergency call box, also known as help points or emergency phones, is a communication device for contacting emergency services or security personnel, often found in public areas. These call boxes serve as crucial points of contact during emergencies, providing immediate assistance when necessary. Make sure they’re visible and accessible from all areas of the parking lot. Don’t forget to provide clear instructions on how to use them.
Park with peace of mind. Arlo’s got your back.
With Arlo security cameras and the Home Security System, your parking lot will be safer than ever. Arlo’s advanced technology ensures comprehensive surveillance, allowing you to monitor your premises more efficiently. Plus, with the Arlo Secure subscription, you gain access to additional security features for extra peace of mind. Together, these solutions will provide a sense of safety for your property, employees, and your loyal customers. And, as you know, happy customers keep coming back.
*The floodlight can be adjusted up to 3000* lumens of brightness when connected to the Outdoor Magnetic Charging Cable. Without the cable, you can adjust the brightness up to 2000 lm.
