Arlo Essential Security Cameras: How to Choose the Best Model
Powerful protection made simple.
Read Now
Arlo Innovations
Share:
Key Takeaways
Arlo Essential cameras make home security simple, offering easy installation, wireless flexibility, and smart features like Color Night Vision and Motion Alerts.
Each model meets a different need, whether you’re looking for full-room coverage, long-lasting battery life, or budget-friendly flexibility.
Use our chart to compare resolution, power options, field of view, and privacy features to build a tailored setup that fits your home and lifestyle.
When it comes to protecting your home, you shouldn’t have to choose between simplicity, performance, and smart features. Arlo Essential security cameras are built to deliver powerful, reliable protection, whether you need wireless security cameras, outdoor security cameras, or a flexible security camera system for complete peace of mind.
This guide breaks down the key differences between each Arlo Essential camera so you can find the perfect fit for your home.
Why choose Arlo Essential?
Millions trust Arlo Essential cameras to blend simplicity with smart, high-performance protection. Whether you’re monitoring your front porch, watching over your backyard, or checking in on a nursery, there’s an Essential camera designed for your needs.
Common features of Arlo Essential cameras include:
2K Video Resolution
Wireless Connectivity
Color Night Vision
Smart Motion Alerts
Weather-Resistant Construction
Easy Installation
Meet the Arlo Essential family.
Arlo’s Essential cameras are affordable, easy to install, and packed with the features that matter most. Most models offer Color Night Vision, Smart Alerts, and crisp 2K Video Resolution, but each has unique advantages as well. Here’s how they compare.
Arlo Essential Pan Tilt
The Arlo Essential Pan Tilt delivers complete room coverage with a 360° horizontal and 180° vertical field of view. It’s ideal for large spaces, busy entryways, or anywhere you want the freedom to pan and tilt to follow the action.
Top Features
Track movement in real time: The camera automatically pans, tilts, and zooms to follow activity so you never miss a moment.
Eliminate blind spots: Full-room visibility gives you total control.
Privacy mode: When disarmed, the camera tilts down for complete privacy.
Hardwired for continuous protection: Perfect for high or hard-to-reach locations that need always-on power.
Privacy control lets you disable video and audio during private moments
Arlo Essential (3rd Gen)
The Arlo Essential 3rd Gen cameras give you the ideal balance of performance, smart features, and effortless installation. With 2K Video Resolution, Dual-Band Wi-Fi, and an updated design, it’s a smart upgrade for any home.
Top Features
Stay connected with 2-Way Audio: Talk to family, pets, or visitors from anywhere.
AI-powered security features: AI detection notifies you about people, vehicles, animals, and packages.
See clearly at night: Record detailed video clips in 2K Resolution, even in low-light settings.
Wide 130° Field of View: Capture more of what matters.
Larger battery lasts 4X longer*, ideal for hard-to-reach areas
Built-in privacy controls for audio and video
*Battery performance may vary. 4x longer when compared to Essential Security Camera (3rd Gen).
Arlo Essential (2nd Gen)
The Arlo Essential 2nd Gen lineup gives you flexibility with both HD and 2K Video Resolution options, plus removable rechargeable batteries on select models for quick swaps without downtime.
Top Features
Integrated Spotlight & Siren (outdoor models): Deter unwanted visitors day or night.
See in the dark: Clear nighttime video lets you monitor around the clock.
Talk to anyone, anytime: With 2-Way Audio, you can talk and listen to visitors, even when you’re not home.
Choose your resolution: HD or 2K to fit your needs and budget.
A flexible home security camera with a strong value
Premium performance in a compact design
Full coverage and real-time control
Charging
Plug-In
Battery
Battery (4X*)
Plug-In
Battery
Battery (4X**)
Plug-In
Plug-In
Plug-In
Video Resolution
HD or 2K
HD or 2K
HD or 2K
HD or 2K
HD or 2K
HD or 2K
HD or 2K
HD or 2K
HD or 2K
Field of View
130°
130°
130°
130°
130°
130°
130°
360°/180°
360°/180°
Night Vision
B&W
Color
Color
Color
Color
Color
B&W
Color
B&W
Privacy Control
Yes
No
No
No
No
No
Yes
No
Yes
Weather Resistant
No
Yes
Yes
Yes
Yes
Yes
No
Yes
No
Connection
Wi-Fi
Wi-Fi
Wi-Fi
Dual-Band Wi-Fi
Dual-Band Wi-Fi
Dual-Band Wi-Fi
Dual-Band Wi-Fi
Dual-Band Wi-Fi
Dual-Band Wi-Fi
2-Way Audio
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Integrated Siren
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
No
Yes
Yes
Yes
Yes
Yes
No
Yes
No
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Base Station and SmartHub Compatible
Yes
Yes
Yes
No
Yes
Yes
No
No
No
Â
Â
Â
Â
Â
Â
Â
Â
Â
Â
*Lasts 4X longer than Arlo Essential 2nd Gen Outdoor **Lasts 4X longer than Arlo Essential 3rd Gen
Upgrade your home security system today.
Explore the full Arlo Essential lineup to build the perfect security camera system for your home. You can also pair any Arlo Essential camera with Arlo Secure to unlock smarter, faster, and more proactive protection.
With Arlo Secure, you get:
AI-powered detection for people, packages, animals, and vehicles.
Smart Activity Zones to reduce unwanted alerts.
24/7 Live Safety Agents to help immediately send first responders to your camera’s location.
Secure cloud video storage so your clips are always protected.
Interactive notifications that let you act instantly from your phone.
Arlo Secure transforms your Essential camera into a truly intelligent security system so you can protect what matters most with even more confidence.
Your home deserves protection that’s simple, smart, and built around your needs. Whether you want flexible indoor monitoring, durable outdoor coverage, or advanced motion tracking, Arlo Essential has a solution designed for you. Choose the camera that fits your space and enjoy the confidence that comes with always knowing what’s happening at home.
