Key Takeaways
Most security cameras store footage for 30 to 90 days, depending on the type of storage (cloud, SD card, or DVR) and the system’s capacity.
Cloud storage offers remote access and automatic backups, while local storage provides physical copies but is vulnerable to theft or damage.
Once storage is full or the retention period ends, older footage is overwritten or deleted, so it’s important to regularly back up important clips and choose a storage plan that fits your needs.
Wondering how long your surveillance footage is stored? Typically, modern security camera systems will keep your video footage for 30 to 90 days. However, the exact answer is trickier than you think and depends on the company, camera model, and your storage system.
A smart home security camera could rely on cloud storage for recording videos, while an older surveillance system might use a digital video recorder or a hard drive. But don’t worry, we’ve researched everything so you can understand how long security footage is kept.
So, what type of video storage options are available?
Essentially, there are two main options: local storage and cloud storage. As its name suggests, local storage relies on storage devices physically located near or in the camera. These could be a DVR, a hard drive, or, back in the day, videotapes. (Let’s leave VCRs in the 90s.) Another example of local storage is security cameras with SD cards. These cameras store video footage on the SD card rather than online.
The higher the storage capacity, the longer you’ll be able to record. For instance, the Arlo Go 2 LTE Security Camera allows you to record and store footage locally with a built-in microSD card slot.
What are the benefits of local storage? The main benefit of local storage is having a physical copy of the security footage. Ironically, this could also be its main disadvantage. Imagine if a thief comes to your house and steals your DVR. If that was your only copy of the footage, there goes your evidence. Also, keep in mind that the amount of storage will determine how much footage you’ll be able to save.
Cloud video storage, on the other hand, uses remote servers to store your security camera footage more reliably. Security systems, such as Arlo’s, upload videos to servers via an internet connection, where the footage is securely stored. This ensures that you always have a backup of your security videos.
Most smart security cameras offer live video streaming and notifications through their mobile apps. However, for actual video recording, you can choose a subscription plan, such as Arlo Secure with 60-Day Cloud Video storage and even 24/7 Professional Monitoring.
How long will my security footage be stored?
Typically, modern security cameras store your footage for 30 to 90 days. However, the storage duration depends on the system in place. From local SD cards to cloud storage, here are some estimated retention periods for easy reference:
Cloud Storage: Security cameras with cloud storage keep recordings for 30 to 90 days, depending on your Cloud Storage plan.
Small vs. Large SD Cards: The storage duration depends on the capacity of your SD card. While a security camera that uses a small SD card can store footage for days, a larger SD card allows recording footage for up to 1 month or more.
DVR: These systems enable you to customize the retention period, ranging from hours to months, depending on the storage capacity.
Do security cameras record all the time?
Not necessarily, but you can set some surveillance cameras, like the Arlo Ultra 2, to record continuously. Continuous recording or CVR allows you to rewind, enabling you to catch anything you might have missed. However, it comes at the cost of recording hours of likely unnecessary footage.
The alternative is to set your security camera to record only when motion is detected. This way, you’ll save storage space, as the camera won’t record every minute of the day. Most modern home security cameras come with motion detection. Consider options like the Arlo 2nd Gen Essential Security Camera, which also features Color Night Vision and 2-Way Audio.
