2. Adjust detection settings for your home security cameras.
Excessive motion detection can drain your battery more quickly. You can easily adjust your camera’s sensitivity through its mobile app, making them less prone to false alarms. Some models also offer power management settings to optimize battery life. For example, the Arlo app provides three setting modes that balance video quality and power consumption. You can also configure your camera to record shorter videos.
3. Keep your cameras’ firmware up to date.
For smart home security cameras, having the most current firmware installed ensures optimal performance. Firmware updates are typically automatic and often include optimizations to help extend battery life. If your camera’s firmware is outdated, you can easily complete the update manually through the app.
4. Place your battery-powered camera in a low-traffic area.
Be sure to place your security cameras correctly, ideally in areas with low traffic and pointing only at zones of interest. Setting a camera in a high-traffic area will drain the battery more quickly. For instance, pointing a camera directly at a busy street will cause it to be activated every few minutes, triggering the recording process and consuming more power.
5. Set up Smart Activity Zones.
If you need to install your security camera in a high-traffic area, consider using features like Smart Activity Zones. For example, with an Arlo Secure subscription, you can highlight specific areas of your property where you want to receive notifications. By excluding unwanted zones, you reduce false alarms and extend battery life.
6. Set an automatic schedule for your security cameras.
With options like Arlo, you can set a schedule to activate and deactivate your cameras automatically. Automation schedules help manage battery life by keeping your cameras active only when needed. For instance, you can turn on your cameras only during weekends while you’re away, or set them to work only at night while you’re sleeping.
7. If possible, keep the camera in temperatures above 32°F (0°C).
Outdoor security systems like Arlo’s are weatherproof, designed to withstand heat, cold, rain, or sun. For example, the Arlo Ultra Security Camera (3rd Gen) can operate within temperatures ranging from -4°F to 113°F (-20°C to 45°C).
