What Is The Difference Between a Floodlight and Spotlight Camera?
Spotlight vs. Floodlight Cameras, decoded.
Read Now
Arlo Innovations
Share:
The main difference between spotlight and floodlight security cameras is the size of the area they illuminate. Spotlight cameras cover small spaces or points of entry, shining a focused light on a location like your doorstep. Floodlight cameras like the Arlo Pro 3 Wireless Floodlight Camera, on the other hand, have a wide field of illumination and are good options for illuminating large areas like yards or driveways.
Proper outdoor lighting can discourage thieves from targeting your property. Both spotlight and floodlight cameras provide illumination and monitoring, but it’s important to choose the right type for your home. Let’s explore the difference between spotlight and floodlight cameras—and help you find the best fit for you.
Spotlight vs. Floodlight Camera: Which camera is best for my security system?
The best camera for you depends on a number of key factors, including property size, weather, and number of entry points. In particular, you’ll want to pay attention to the size of the space being monitored. Do you have big outdoor spaces? A single, bright LED floodlight camera can cover a large yard thanks to built-in 2K video with HDR. However, it might take multiple spotlight cameras to cover the same square footage.
Where can I use a floodlight camera?
LED-powered floodlight cameras are great options for monitoring outdoor spaces. Options like the Ring Floodlight Cam or the Pro 3 Wireless Floodlight Camera are built to protect alleyways, driveways, and other expansive areas with a bright & broad light output. Upgrade your existing outdoor floodlight with a powerful 2K security camera built right into the Pro 3’s bright LED floodlight for all-in-one security.
Where can I use a spotlight camera?
A spotlight camera is better suited for targeted areas such as your front or back door. a brighter light could be disorienting to regular visitors. Pro tip: Spotlight security cameras are good options for monitoring points of entry due to their focused narrow beam light. Spotlight cameras like the Ring Spotlight Cam or the
Arlo Essential Security Camera (3rd Gen)offer an integrated spotlight to illuminate your entryway, porch, or side yard and is ideal for smaller spaces without sacrificing on video quality, reliability and outdoor durability.
What should you look for in a new outdoor camera?
When evaluating which new outdoor camera to buy, you should focus on a range of applications. Be sure to pick a new outdoor camera that fits your needs. For example, consider a well-placed floodlight camera to see who approaches your property if you need to monitor a wide area. If you have multiple points of entry, select a spotlight camera to monitor doorways. Keep an eye out for key features like 1080p video resolution, wire-free installation, and a rechargeable battery.
Before you “add to cart,” you should:
Prioritize a 100% wireless design.Connecting to Wi-Fi or an LTE network is much more convenient than running wires through your walls or across the property. For example, connect the Arlo Essential Security Camera (3rd Gen)directly to your existing Wi-FI network for fast, wire-free installation.
Pick a provider with a smartphone app. The ability to check in on your home from wherever you are is a major selling point — and it’s easy to see why. Pick a provider that offers a convenient, easy-to-use smartphone app. When you buy an Arlo camera, for example, you get a free trial of Arlo Secure to keep your family and home protected with just one tap. With interactive notifications and Emergency Response, you can get immediate help from first responders. Plus, with Professional Monitoring, you can get Safety Agents monitoring your home so you don’t have to.
Choose motion-activated monitoring. To conserve power, pick a camera where the light and camera only turn on when triggered by a moving person or object. With an Arlo Secure subscription, you can monitor smart activity zones from day one.
Keep an eye out for solar powered monitoring.Many cameras use long-lasting batteries or even solar panels for power, which offer a simple alternative to working with electrical wiring. Explore Solar Powered Security Cameras for easy, wire-free installation. Plus, pick LED light bulbs that last longer and use less power than conventional lights.
Protecting your home is easier than ever with so many innovative products on the market. With a bit of research—and Arlo by your side—you can build the most effective security system for your property today.
