Do Arlo Cameras work with Google Home?
Yes, you can easily connect Arlo cameras to Google Home. To set up your Arlo Google Home properly, you’ll need one or more compatible Arlo devices and the Google Home Hub or Chromecast device. Don’t forget to download both the Google Home and Arlo apps from the app store.
There are a few Arlo cameras to choose from that work with Google Home, but all are excellent choices:
What doorbell cameras are compatible with Google Home? Both of the following Arlo video doorbells are compatible with Google Home:
Using these three devices and apps, your house’s new security features will be up, running, and connected to your phone on the go.
How to set up Arlo security cameras with Google Home today.
Once you’ve set up the Arlo Secure App, Google Home app, and Google Assistant on your phone or tablet, you’re ready to connect with Google Home. Let’s explore how to set up all of your Arlo devices with Google Home in a few simple steps.
1. Install the Google Home app.
First, you’ll need to download and install the Google Home app if you haven’t already. Then, you can add a new device to the system. Pro tip: Make sure you have downloaded the Arlo Safe or Secure app before proceeding to Step 2. Make sure your new Arlo security camera or doorbell is on and fully discoverable.
2. Add a new device.
Once the Google Home app is installed, you’re ready to add your preferred Arlo device to the system. Tap the “+” button. Click on the first choice you see, which should read “Set Up Device.”
Then, select “Have something already set up”. You should now see “Arlo” appear on screen. Select this choice.
3. Log in to your Arlo account.
If you’re already an Arlo user, simply log in to your Arlo account using your Arlo email and password. If you’re new to the Arlo family, download the Arlo Secure App from the Apple App Store or the Google Play App Store. After putting your login information on the screen, Google will ask for access to your Arlo account. Hit the “Allow” button. Google will now start synchronizing all your Arlo devices.
4. Synchronize devices across the rooms of choice.
Tap on each synchronized device as it appears on the screen. Carefully pick the rooms where you’d like to set up that device. If you are not able to link your Arlo Account in the Google Home app for any reason, be sure to unlink and then relink your My Arlo account.
Now, all your Arlo devices should be part of your new Arlo Google Home. You’re all set!
