Key Takeaways
Arlo security cameras, such as the Ultra Security Camera (3rd Gen), Pro 3 Floodlight, and Pro Security Camera (6th Gen) are compatible with Apple Home.
Linking Arlo to Apple Home gives you access to voice control through Siri, live video streaming, motion alerts, and the ability to manage all devices from one app.
An active connection to Arlo Pro SmartHub is required for Apple Home connectivity.
From home lighting to music and even electronic locks, most Arlo security cameras and video doorbells work seamlessly with your smart home security system — and Apple Home is no exception. Let’s find out what makes Apple Home so useful, and how to add Arlo to Apple Home today.
Wait, does Arlo work with HomeKit?
What is Apple Home, and what is Arlo’s compatibility with Apple HomeKit? Apple Home, formerly known as Apple HomeKit, is a convenient smart home platform fully compatible with Apple devices.
Apple’s redesigned Home App allows you to seamlessly control your smart home accessories on your Apple devices. Although not every Arlo security camera or video doorbell is Apple Home compatible, you can connect it to several of Arlo’s most popular products, including these compatible cameras:
Why should I link the Apple Home App with my Arlo Pro SmartHub?
Whether you’re using an iPad, iPhone, or your Apple Watch on the go, enjoy peace of mind with the convenience of Apple Home. With Apple Home and a compatible Arlo device, you can use voice commands to access and control multiple Arlo cameras and doorbells from one place.
Connecting Apple Home to your Arlo Pro SmartHub allows you to:
Leverage voice commands: You can easily rattle off commands for Siri to voice control your Arlo devices.
Enjoy unique security features: Use the Apple Home App to stream your Arlo feed, the 2-way audio feature, receive motion alerts in the Arlo app, and so much more!
Build a comprehensive system that works for you: Go ahead, curate a smart device system incorporating all of the security essentials you might need. From automated security cameras, lights, locks to a live video feed, protect your everything from the comfort of your iPhone or iPad.
Streamline security with automation: The beauty of a Smart Home system? You can automate Arlo camera and doorbell functions all in one place.
Connect Arlo with your Apple TV: If you have Apple Home, chances are you’re a tech enthusiast. If you’re anything like us, you love rounding out the week with a new episode of your favorite show. With Arlo connected to Apple Home, you can sit back, relax, and stream your Arlo camera on your Apple TV today.
What else do I need for my Arlo HomeKit?
To take full advantage of the above key features, you need a supported and connected Arlo system. Setting up your cameras or video doorbell with Apple Home will require a few extra features, including the Apple Home App, the Arlo Secure App, and an Arlo Pro SmartHub.
To use Arlo with Apple Home, you’ll need:
1. Apple Home App
Available on many Apple products, the Apple Home App lets you control your smart accessories using your Apple device. Although your smart accessories all have their apps, it can be tedious switching from one to the other. Home lets you set up your compatible devices for easy control of your smart home technologies from one convenient location, including air conditioners, lights, garage doors, security systems, cameras, and more.
2. Arlo Secure App
Necessary for fine-tuning your Arlo products, the Arlo Secure App is an integral part of your security setup. You can easily control and interact with all of your Arlo products, while also storing video and audio recordings that you can view from wherever, whenever you need them.
If you’re new to the Arlo family, download the Arlo Secure App from the Apple App Store or the Google Play Store. After putting your login information on the screen, Apple Home will ask for access to your Arlo account. Hit the “Allow” button. Apple will now start synchronizing all your Arlo devices.
3. Arlo Pro SmartHub
The Arlo Pro SmartHub models make it easier to securely connect your Arlo devices and home security system to your internet via your home router.
Options like the Arlo Pro SmartHub are compatible with Apple Home while providing long range connectivity and better battery life for your cameras. Keep an eye out for key features, including local storage and 4K streaming resolution with compatible cameras.
Why do I need to use an Arlo Pro SmartHub?
You need an active connection to an Arlo Pro SmartHub to use Apple Home with your Arlo cameras. Connecting directly to a Wi-Fi router is not viable, as your connection will be less secure. Without a SmartHub in place, anyone with access to your Wi-Fi could gain access to your private recordings, cameras, and more.
Keep in mind: Base Stations are compatible with earlier Arlo camera models, but SmartHubs have greater compatibility with our newest models like the Arlo Pro Security Camera (6th Gen).
How to set up your Arlo Video Doorbell or Camera with HomeKit.
Setting up your Arlo video doorbell or camera with Apple Home is simple. Pro tip: When you first connect Arlo to Apple Home, you must be on the same Wi-Fi network as your Arlo Pro SmartHub or Arlo Base Station.
Then, you can link your Arlo device with or without an Apple Home setup code. Find out how to set up your Arlo camera to Apple Home today. Great news: You’re one step closer to your dream smart home.
