The key to 24/7 peace of mind? Avoid these common mistakes.
Read Now
Best Security Setups
Share:
Research shows that security cameras can effectively deter crime, especially when properly placed and maintained. Camera installation is crucial: when done correctly, security essentials can significantly enhance your system’s effectiveness. However, if you’re installing cameras for the first time, mistakes are common. Don’t worry — here are seven common security camera installation mistakes and how to avoid them.
7 mistakes to avoid when installing security cameras.
When installing home security cameras, avoid choosing poor locations, installing them too low, or blocking their field of view. Once installed, remember to maintain them regularly and keep them charged or connected to a power source. Here’s a closer look at each mistake.
1. Don’t choose the wrong locations for your security cameras.
Before drilling holes in your walls, make sure you choose the optimal placements for your cameras. Pro tip: You’ll want to avoid blind spots and prioritize key access points, such as front doors and windows. Make sure the cameras have an unobstructed view of the area, free from any objects blocking their sight. Use cameras like the Arlo Ultra Security Camera (3rd Gen) with superior coverage, featuring an ultra-wide 180° Field of View and 4K HDR video recording.
2. Don’t install security cameras too low.
Security cameras provide optimal protection when installed in an elevated position with a clear, comprehensive view of the area. Positioned in a corner or at an elevated angle, options like the Arlo Essential Security Camera (3rd Gen) enable you to capture every detail, from corner to corner. Whether you opt for professional installation or choose the DIY approach, ensure your cameras are positioned at the correct elevated angle.
3. Don’t rely on a single security camera.
On its own, a single camera is usually not enough to protect an entire home. But what’s the right number of cameras for you? It depends on the size of the property, but for the average home, it typically ranges from two to six cameras. This usually includes a mix of outdoor security cameras covering entry points and at least one indoor camera, often placed in the living room.
Pick the right number of cameras based on your home’s layout for complete coverage. You can also amp up your security by adding an alarm system like the Arlo Home Security System. This system comes with handy All-in-One Sensors that can detect and monitor up to eight different threats.
4. Don’t sacrifice coverage to keep your cameras hidden.
Hidden cameras — either battery-powered cameras or wired security cameras — can offer both pros and cons. If you choose to hide your security cameras, make sure their perspectives are never compromised. Always maintain a clear view of the area, free from any obstructions blocking the lens.
5. Don’t neglect camera maintenance.
Many DIY security camera systems are designed to be low maintenance. They don’t require clearing space on a digital video recorder or constant monitoring in front of a security screen. However, occasional security maintenance is necessary. Essentially, you’ll want to keep your cameras clean, frequently test their alarm sensors, and ensure they always remain charged (more on that in the next section).
6. Don’t let your cameras lose power.
Security cameras are designed to operate 24/7. If they become discharged or lose power, you’ll lose access to their video feed and, ultimately, security. Keep this in mind when installing wireless security cameras. Make sure they are within reach for easy removal and charging, or connect the cameras to a compatible Solar Panel Charger for a continuous, hassle-free power source.
7. Don’t choose the wrong cameras.
Ultimately, there’s no bigger mistake than choosing the wrong security cameras. The type of camera you select will shape the quality of your home security and, ultimately, your peace of mind. While it can be tempting to select the cheapest option, there’s an important distinction between a cheap camera and a budget-friendly one. You’ll want to purchase a fully-featured, reliable, and reputable security camera.
Make the smart choice. Choose Arlo for your home security today.
Brands like Arlo provide DIY security camera systems to suit any budget, ranging from entry-level options like the Arlo Essential Security Camera (3rd Gen) to advanced models like the Arlo Ultra Security Camera (3rd Gen) with 4K HDR video. Plus, they are easy to install, saving you the cost of hiring a professional.
While budget-friendly, these options come equipped with comprehensive features for year-round protection. With motion sensors, Integrated Spotlights, Color Night Vision, and more, you can trust that any Arlo camera you choose is a reliable choice.
