Arlo Ultra 2 vs Pro 5S 2K: Security Camera Comparison
Let’s compare Arlo’s state-of-the-art cameras.
Read Now
Home Security Tips
Share:
Looking for the ultimate home security camera? You’ve probably heard of the Arlo Ultra 2 and the Arlo Pro 5S 2K cameras. Both are state-of-the-art, high-resolution cameras, but which one is right for you? Let’s compare these Arlo cameras so you can make the best decision.
Arlo Pro 5S 2K: Features and price.
The Pro 5S 2K ($249.99) is a wire-free security camera that features HDR video with 2K resolution and 12x zoom. It comes with a wall mount and a magnetic charging cable. The Pro 5S 2K includes everything you would expect from a high-end DIY security camera, such as 2-Way Audio, Motion Detection, Color Night Vision, and an Integrated Spotlight. You can use the Arlo app to monitor a live feed from the camera and receive notifications when motion is detected. The Pro 5S 2K offers a wide 160° Field of View.
Arlo Ultra 2: How much does the security camera cost?
The Ultra 2 ($299.99) is a wireless security camera that features 4K HDR video and a 12x digital zoom, resulting in more detailed security footage. Like the Pro 5S 2K, it also comes with a wall mount and a magnetic charging cable. The Ultra 2 includes 2-Way Audio, Motion Detection, Color Night Vision, and an Integrated Spotlight. Additionally, the Ultra 2 offers an ultra-wide 180° Field of View, giving you a more expansive view of the surroundings.
Arlo Pro 5S 2K vs Arlo Ultra 2: What’s the difference?
Overall, both security cameras offer comparable features, but while the Arlo Pro 5S 2K records video in 2K resolution, the Arlo Ultra 2 records in 4K resolution. The Arlo Ultra 2 also boasts a wider 180° field of view compared to the Pro 5S 2K’s 160°. In short, for the $50 difference in price, the Arlo Ultra 2 provides a wider field of view and higher 4K resolution.
1. What are the storage options for both security cameras?
Both Arlo security cameras are compatible with local storage and Cloud Storage. For local storage, you can set them to record to a MicroSD card or USB flash drive when synched to an optional hub, like the Arlo Ultra SmartHub.
For Cloud Storage, both cameras are compatible with the Arlo Secure subscription, which starts at $7.99 for one camera or $12.99 for unlimited cameras. Arlo Secure provides a 30-day video history. Plus, Arlo Secure enhances both cameras with additional features like Activity Zones and AI Smart Object Detection.
2. How is the battery life for the Arlo 2 and the Pro 5S 2K cameras?
Both cameras feature long-lasting battery life, thanks to their high-capacity rechargeable batteries. You can also connect them to a Solar Panel Charger to extend their battery life using solar energy. The Pro 5S 2K also features a low power mode that allows the camera to extend its battery life by taking snapshots instead of recording video.
3. Do you need a base station to use these security cameras?
No, the Pro 5S 2K does not require an Arlo Base Station to work. The Arlo Ultra 2, on the other hand, needs a base station. A base station, also known as a SmartHub or base unit, is a central unit that connects a network of security cameras. With select Arlo cameras, a base station is entirely optional. You only need the camera and a smartphone with the Arlo app to protect your home.
What’s the security camera for you?
Both Arlo security cameras offer premium features at affordable price points. Choosing between them depends on your specific security needs. If you want the most detailed, crystal-clear security footage, choose the Ultra 2 with 4K video. If 4K resolution is not a priority, the Arlo Pro 5S 2K will keep your home equally protected. Whether you choose the Arlo Ultra 2 or the Arlo Pro 5S 2K, choose the right security camera for your needs.
