3. Test your alarm sensors.
Start by inspecting all your sensors to ensure they are securely attached to windows, walls, and doors. Then, test each sensor to verify that it is working properly and sending notifications to your security app. If a sensor isn’t functioning, check whether it needs new batteries or a reconnection to your system.
Take the time to evaluate if there are additional areas in your home that could benefit from alarm sensors. Options like the Arlo Home Security System can monitor not just doors and windows but also detect water leaks, temperature changes, light variations, and more.
4. Do a perimeter check.
Walk around your property to spot any potential access points and hiding spots. This proactive approach can help prevent home invasions, as studies show that many burglars act on opportunity after noticing a gap in security. Check for loose fence planks or trees that could aid someone in reaching a window. Keep your fences well-maintained, trim bushes, and ensure your yard is clear of large items like ladders and boxes.
5. Check every smoke and carbon monoxide detector.
Regularly check each smoke and carbon monoxide detector to ensure they are functioning properly. Test the alarms to confirm they sound correctly and replace the batteries as needed. With an Arlo Secure subscription, your Arlo All-in-One Sensors and security cameras can monitor smoke and carbon monoxide detectors, alerting you promptly if an alarm is triggered.
6. Update your smart security app and run diagnostics tests.
Your security system mobile app is the hub for your home security, so it’s important to keep it up to date. Regularly update your smart security app and run diagnostic tests to keep everything working smoothly. Updates can provide important security fixes and new features, while diagnostics help spot and fix any issues with your devices or connections. This helps ensure your security system stays reliable and effective.
The Arlo app offers all the features, settings, access to video recordings, and live feed for your Arlo security system. With an Arlo Secure subscription, you gain access to extra features, including Cloud Video Storage for your video events, available for up to 30 days.
7. Keep a strong, reliable Wi-Fi network.
Since most wireless security cameras connect to a Wi-Fi network, it’s important to keep your network secure. Use a strong password and enable WPA3 encryption if your router supports it. To improve Wi-Fi signal, consider upgrading your router, changing passwords regularly, and adjusting your router’s placement for better coverage.
8. Move objects away from the camera’s point of view.
Make sure to move any objects that might obstruct your cameras’ view. Items like potted plants, tree branches, or outdoor decor can interfere with the camera’s recording. Keeping the camera’s line of sight clear ensures you get a complete and accurate picture of your surroundings.
9. Check your security lights.
Security lights play a crucial role in outdoor lighting. Motion-activated lights turn on automatically when they detect movement, helping to prevent accidents and deter potential intruders. Ensure that each security light is functioning correctly and that motion detection is working as intended.
For enhanced security, consider options like the Arlo Pro 3 Floodlight Camera, which combines a powerful 2K security camera with a bright LED floodlight. Also, many modern security cameras also include built-in spotlights. Options like the budget-friendly Arlo Essential Security Camera (3rd Gen) or the 4G/LTE-enabled Arlo Go 2 Camera offer both effective lighting and security.
