The key to catching every detail? Keep your security cameras clean.
Read Now
Home Security Tips
Share:
Cleaning your security cameras is an essential part of maintaining your home security system. Regular cleaning improves image quality, reduces false alarms, and enhances overall performance.
What’s the best way to clean a security camera? Should you use a lens cleaning solution? Are there any risks of scratching the lens surface? Let’s explore how to help you effectively clean your security cameras.
Why should you clean your security cameras?
Debris, dust, fingerprints, and humidity can all reduce the image quality of your security cameras. These elements can also trigger motion sensors, which can spark false alarms. Additionally, dirt buildup can damage your cameras over time. Regular cleaning helps prevent these issues and keeps your home security system in top condition.
How to clean outdoor security cameras.
To safely and effectively clean your security cameras, start by dusting them, then wipe them with a microfiber cloth. Pay extra attention when cleaning a dirty camera lens. You can dampen the cloth with water or a drop of dish soap.
Indoor cameras are typically easier to clean, such as the Arlo 2nd Gen Essential Indoor Camera. Outdoor cameras, on the other hand, are exposed to the elements and tend to get dirtier more easily. Expect to put in a little extra elbow grease when cleaning outdoor cameras. Here’s a step-by-step guide to cleaning your cameras.
1. Prep the cleaning area.
Start by unplugging your wired cameras and unmounting your wireless ones. Turn off your cameras and bring them to your cleaning area. Then, prepare with a little water, optional dish soap, and a microfiber cloth. In many cases, a compressed air duster is also recommended.
Pro tip: Avoid using paper towels, as they can scratch surfaces. Plus, consider removing the batteries from your wireless cameras for a deeper clean.
2. Dust and clean your cameras with a microfiber cloth.
Using a dry microfiber cloth, gently dust your security cameras. Take your time to thoroughly clean around cracks, buttons, and cable ports. Cameras like the Arlo Go 2 4G/LTE Camera may have additional ports to clean, such as the MicroSD port for local storage recording.
3. If needed, use water or dish soap.
Over time, debris and other residues may stick to your outdoor security cameras. Do you see stubborn residue that won’t budge? No problem. Simply use a little water to loosen dust particles. Dampen your microfiber cloth and put in some elbow grease. If you’re still struggling to clear the way, you can also consider using a single drop of dish soap, as it may help dissolve dirt and make cleaning easier.
Pro tip: Don’t worry about water damaging your cameras. All Arlo outdoor security cameras are weatherproof. Options like the Arlo Ultra 2— one of the best 4K security cameras—are designed to withstand heat, cold, rain, and sun.
4. Be extra careful when cleaning the security camera lens.
Pay extra attention when cleaning the camera lens to avoid scratching the lens. Make smooth circular motions, starting from the center of the lens. Be careful not to damage the lens coating or leave any marks, as dust particles can scratch the surface. Avoid using lens cleaning solutions, glass cleaners, or any chemical cleaners, as most camera lenses have a special coating that can wear off. With this in mind, stick to water.
A clean camera lens ensures clearer image quality, minimizing false alarms caused by debris activating the motion sensors.
5. Dry the cameras with a clean microfiber cloth.
After cleaning your cameras, use a fresh microfiber cloth to gently dry them. This will help remove any remaining moisture and prevent streaks or water spots. Be sure to use a clean cloth to avoid introducing new dust or debris to the lens. This step is crucial for maintaining clear image quality and overall camera performance.
6. Protect your security cameras clean with a cover.
For extra protection against the elements, consider using silicone covers. For example, Arlo offers Protective Camera Covers. These silicone skins are UV and weather-resistant, making them ideal for both outdoor and indoor use. Their convenient slip-on, slip-off design helps protect your cameras while providing easy access for mounting and battery charging.
Guarantee crystal-clear video with Arlo 24/7.
Arlo security cameras and video doorbells provide superb, high-quality video for everyday home security. By keeping your cameras clean, you ensure they perform at their best, delivering clear and reliable footage for your peace of mind. Additionally, regular cleaning helps extend the lifespan of your cameras, making the most of a budget-friendly security system. Cleaning your security cameras brings only benefits, enhancing both performance and durability.
