Energy savings: good for the planet—and your peace of mind.
Read Now
Home Security Tips
Share:
Wondering how to conserve energy at home? While reducing your electricity bill might seem daunting, it’s simpler than you might think. By adjusting daily habits and upgrading some old appliances, you can save energy—and money—in a few simple steps. Let’s explore how to effectively reduce your energy usage at home today.
What is energy conservation vs. energy efficiency?
According to the U.S. Energy Information Association, energy efficiency and conservation are complementary approaches aimed at reducing energy usage. Energy efficiency focuses on improving the technical performance of devices, while energy conservation involves actions to reduce overall energy consumption.
For example, if you opt for a new eco-friendly water heater, that’s improving energy efficiency. But if you also decide to take shorter showers, that’s a form of energy conservation.
How to reduce energy (and your electricity bill) in 7 simple steps.
Curious how to save energy at home? Try switching to energy-efficient lighting, using solar energy, installing a programmable thermostat, and reducing hot water usage. You can also keep doors and windows closed, be more conscious when using your washing machine, and use the Energy Saving settings on modern appliances.
Here are eight tips for saving energy, reducing your carbon footprint, and lowering your electricity bill.
1. Switch to energy-efficient LED light bulbs.
Are you still using incandescent light bulbs? Consider switching to LED bulbs, which are considerably more energy-efficient and will last longer. While LED light bulbs may have a higher upfront cost compared to incandescent lighting, you’ll save money in the long run.
Moreover, what’s even more energy-efficient than LED bulbs? Natural lighting. Try opening curtains and blinds during the day to let in natural light, reducing the need for artificial lighting.
2. Harness the power of the sun with solar panels.
You don’t have to make a big investment to take advantage of solar power. In addition to roof solar panels that can provide energy for your entire home, there are also small-scale solutions for everyday devices. For instance, smartphone solar chargers and solar garden lights are great options.
To further enhance your energy conservation efforts, you can pair them with a Solar Power Charger. Arlo solar chargers keep your cameras’ batteries charged using direct sunlight. They’re weather-resistant, feature an 8-foot magnetic power cable, and include an adjustable mount for easy installation.
3. Install a smart, programmable thermostat.
Air conditioning and heating are among the main contributing factors to your natural gas and energy bill. If you haven’t already, consider investing in a smart thermostat. A programmable thermostat allows you to adjust your air conditioner or HVAC system to match your schedule. It will automatically reduce heating or cooling when you’re not home or asleep to save energy.
How often do you replace your home’s air filters? It’s important to keep your air filters clean, especially in your HVAC system. Try to follow the manufacturer’s guidelines on replacement frequency. Switching dirty filters for new ones can lower your air conditioner’s energy consumption by 5% to 15%. Also, schedule professional maintenance to ensure these systems remain in optimal working condition.
5. Keep doors and windows closed.
Drafts and air leaks can greatly affect your heating or cooling efficiency. Keep not only exterior doors and windows closed but also interior doors between rooms. This helps retain indoor heat, saving energy and maintaining your desired temperature. So, anytime you leave a room, remember to close the door.
The U.S. Department of Energy states that your washer will use about the same amount of energy regardless of the load size. So, it’s best to fill it up to reduce the frequency of washes. Additionally, they recommend washing in cold water and air drying whenever possible. If you own an older washing machine, consider replacing it with an Energy Star-certified clothes washer. Also, to further reduce energy consumption, you can also consider opting for a gas dryer.
To decrease your water bill, ensure there are no water leaks in your laundry room, kitchen, and basement. The Arlo Home Security System also includes a water leak detection feature. Simply install the All-in-One Sensors under pipes to detect water and frozen pipes.
7. Reduce water heating expenses.
While we all enjoy a long, hot shower, using your water heater can significantly impact your water and electricity utility bills. Consider making small sacrifices, such as taking shorter showers and washing clothes in cold water whenever possible. Insulating hot water pipes can also help reduce heat loss and further save on energy costs.
8. Use the Eco or Energy-Saving settings on your appliances.
Modern appliances, such as stoves, dishwashers, and washing machines, often offer energy-saving modes or settings. Utilizing these features can help reduce energy consumption during operation, leading to cost savings and environmental benefits. Consider giving these energy-saving settings a try next time you use your appliances.
With Arlo, energy savings come with peace of mind.
The Arlo Home Security System lets you monitor and detect water leaks, open doors and windows, and temperature changes. Moreover, you can safeguard your home with motion detection and contact sensing, ensuring security at every entry point. Plus, Arlo security cameras provide crystal-clear monitoring for your home without increasing your electricity bill.
With Arlo’s energy efficient products, you can enjoy double the peace of mind for you — and the planet.
