2. Install motion sensors around the pool.
Motion sensors work by detecting heat. Around a pool, they can be crucial for preventing fatal accidents. If someone falls into the pool, the motion sensors will send a notification to your smartphone, giving you time to respond quickly.
Consider options like the Arlo Home Security System. This comprehensive alarm system includes the Arlo All-in-One Sensors. In addition to motion detection, they can monitor doors and windows, water leaks, light and temperature changes, and more.
3. Use a pool safety cover when the pool is not in use.
The most effective way to prevent dirt buildup in your pool is to keep it covered. A well-fitted safety cover also helps maintain water quality and cleanliness. You can choose from various pool cover options, ranging from mesh to heavy-duty models.
If you’re unsure how to install a pool safety cover, you can always hire a professional to handle the job. Depending on the material, a professionally installed heavy-duty pool cover can be a long-term investment, with lifespans of up to 30 years.
4. Store pool chemicals in a locked area.
Any pool owner knows that maintaining a pool requires chemicals like chlorine. These substances can be dangerous to young children, who might accidentally ingest or touch them, causing burns or rashes. Always store these pool chemicals in a locked, out-of-reach area. For added safety, consider monitoring this area with the Arlo Home Security System or a newly installed Arlo security camera.
5. Install a pool fence.
According to the Red Cross, 87% of drowning fatalities for children younger than 5 occur in home pools or hot tubs. A pool fence is essential for keeping unsupervised children and pets away from a home pool. In fact, in most states, it’s mandatory. Building codes typically require pool fences to be at least 48 inches high.
You can choose from various options, including mesh pool fences, chain link fences, and removable pool fencing. Your choice will ultimately depend on your budget and aesthetic preferences. How much does a pool safety fence cost? On average, a pool fence ranges from $1,500 to $10,000, depending on the size of the pool and fencing material. Pool fence installation costs can also increase the total price. However, you can save money by installing the pool safety fence yourself if you have the know-how.
6. Illuminate the pool area with a floodlight.
A well-illuminated pool area can prevent accidents, especially at night. You can enhance safety and visibility with a motion-activated floodlight. Consider options like the Arlo Pro 3 Floodlight Camera, which combines a powerful LED floodlight with a built-in 2K security camera. Plus, with a wide 160° Field of View, you’ll always have the best view of your pool area.
