What features should I look for in a 4K outdoor camera?
When looking for 4K security cameras, prioritize high-quality video resolution, night vision capabilities, a wide field of view, motion detection, weather resistance, and good battery life. Let’s dive into each feature to help you make an informed decision.
1. Image quality.
If you’re looking for 4K security cameras, you’re already prioritizing image quality. As mentioned earlier, 4K cameras provide the most detailed, high-quality security footage for your home. Options like the Arlo Ultra 2 allow you to take advantage of every extra pixel, thanks to its 12x Digital Zoom.
2. Night Vision.
Night vision enables your camera to record video in low-light conditions or total darkness. However, not every security camera offers the same type of night vision capabilities. There’s PIR night vision, which produces the classic black and white security footage. Then, there’s color night vision, which uses an integrated spotlight to record full-color video regardless of the light conditions.
For optimal security, look for 4K cameras that feature both PIR night vision and color night vision, such as the Arlo Ultra 2.
3. Wide Field of View.
Field of View (FOV) is the maximum area a camera lens can see, usually measured in angles. Why is Field of View important? A wider FOV provides a broader image of your surroundings, letting you be aware of additional threats.
Most cameras offer a FOV between 120 and 150°. Others, like the Arlo Ultra 2, boast an impressive ultra-wide 180° viewing angle.
4. Motion Detection.
When movement is detected, motion sensors will trigger video recording and send an alert to your smartphone. In home security cameras with integrated spotlights, motion detection also automatically activates the light to catch potential intruders off guard and deter them.
5. Weather resistance.
Whether your 4K security camera is for indoor or outdoor use, weather resistance should be a priority. A weatherproof camera will hold up in inclement weather and is ideal for jobsite security or construction site security. Options like the Arlo Ultra 2 are designed to withstand heat, cold, rain, snow, and sun.
6. Battery life.
Wireless 4K security cameras require more battery power for 4K recording. Therefore, it’s crucial to choose a security camera with long battery life. Options like the Arlo Ultra 2 offer long-lasting battery life. Plus, it can also be connected to a Solar Panel Charger for harnessing the natural energy of the sun.
