Many people think home security is too expensive, and with good reason: Traditional home security companies usually don’t hold back on fees, costs, and contracts. The result? People think they can’t afford a reliable home security system.
But home security—and the peace of mind that comes with it—doesn’t need to be expensive. So, let’s explore the typical costs associated with installing a home security system. Then, let’s discover budget-friendly alternatives. Spoiler alert: DIY is the way to go.
How much does traditional home security cost?
Truth be told, traditional home security systems can indeed be overpriced. Let’s start with why they are expensive, normally. Unlike DIY smart home security systems, traditional security companies tend to charge for equipment, installation costs, maintenance, and monitoring fees. And above all, they often lock you into a long-term contract.
Here’s a breakdown of all the costs that typically come with a new system:
Equipment. This covers the initial purchase of home security equipment. For example, security cameras, motion detectors, contact sensors, keypads, and other devices.
Installation. Many traditional security companies may charge installation fees for professional setup of the security system in your home. Wired systems typically incur higher installation costs compared to wireless systems.
Contractual commitments.Traditional security companies often offer long-term contracts. Early termination of these contracts may result in penalties or fees.
Monthly monitoring fees. Professional monitoring services usually include 24/7 monitoring for security breaches, fire incidents, and other emergencies, with a monitoring center promptly contacting authorities if necessary.
App fees.There may be extra charges for additional features or services. For example, remote access to your security system via smartphone apps, or smart home integration.
5 reasons DIY home security doesn’t have to break the bank.
Security companies like Arlo challenge the status quo by offering DIY home security systems. You can easily build a budget home security system, protecting your home while saving money.
DIY home security is considerably cheaper because there are no installation fees, no contracts, and it requires a lower initial investment. They’re also typically contract-free, and monitoring plans are optional. Let’s dive deeper into the benefits of DIY home security systems like Arlo’s.
1. No installation fees.
DIY systems, also known as “do-it-yourself” systems, are fully customizable and designed for easy setup. DIY systems tend to be more affordable because you don’t need professional installation or fees. You can place a security camera like the Arlo Ultra Security Camera (3rd Gen) with the included mount, while other models like the Arlo 2nd Gen Indoor Camera don’t require installation at all. Options like the Arlo Video Doorbell require only two screws to be wall-mounted.
Easy installation also means added flexibility. For extra convenience, opt for a Magnetic Wall Mount. If you prefer additional security, choose an Anti-Theft Mount. And when it’s time to move out, you can easily uninstall the cameras yourself, without a visit from a security company.
2. No long-term contracts. Or even better, no contracts at all.
Unlike traditional security systems that often require long-term contracts, DIY options typically offer flexibility with no contractual commitments. This means the equipment you pay for is yours, and you’re not tied into paying monthly fees. People don’t buy a contract, they simply purchase the camera they want.
When you purchase an Arlo security camera, video doorbell, or home security system, you can use it freely, self-monitoring your home without the need for additional payments.
3. Lower equipment costs. You only get what you need.
Traditional security companies offer starter kits with security devices you probably don’t need, increasing upfront costs. DIY systems often feature affordable equipment options, allowing you to choose the devices that fit your budget without sacrificing quality.
For instance, options like the Arlo Essential Security Camera (3rd Gen) cost only $39.99, offering features usually found in higher-end models. This camera boasts Color Night Vision, Motion Detection, 2-Way Audio, and an Integrated Spotlight.
4. Monitoring plans are optional.
With DIY home security systems, products or services are always optional and flexibility is key. For instance, you can install the Arlo Home Security System and save money by monitoring your home yourself. But, if you find Professional Monitoring worth it, you can opt for the Arlo Secure subscription.
Professional Monitoring is a helpful service where trained experts keep an eye on your security system. If an alarm is triggered, they’ll step in and reach out to you or the emergency services. Professional Monitoring ensures peace of mind and swift assistance whenever needed, even when you’re not available.
5. You get advanced features without subscriptions.
Options like Arlo offer free access to remote monitoring via their smartphone apps, allowing you to check in on your home without additional subscription fees. The same goes for integrating your security system with smart home devices. Most Arlo home security devices can connect with Google Home, Amazon Alexa, Apple Home, and more. That means you can start with home automation without any subscription.
If you’re interested, you have the option to subscribe to Arlo Secure to enhance your security cameras’ capabilities. With Arlo Secure, you’ll enjoy features like 60-Day Cloud Storage, AI Smart Object Detection, and Smarter Notifications. Plans start at just $7.99 per month.
Are Home Security Systems worth it? With Arlo budget-friendly home security, yes!
While there are costs to install a reliable home security system, the cost of a break-in is significantly higher. Save yourself the stress and money by partnering with a home security system on a budget. With Arlo, home security is definitely not expensive.
Arlo security cameras, video doorbells, home security systems, and optional subscriptions, make peace of mind more accessible than ever. Say goodbye to large bills from traditional security companies — and protect your home without breaking the bank.
