Brighten your outdoor security with a wired floodlight camera.
Read Now
Home Security Tips
Share:
Security cameras and outdoor lighting are two of the best measures you can take to protect the outdoor areas of your home. Together, they efficiently deter potential intruders and improve your peace of mind. Luckily, there’s a new security device on the market that combines both into one convenient solution: Arlo’s Wired Floodlight Camera.
But how exactly are floodlights mounted, and where’s the best place to install them? Can you install one yourself, or should you hire a professional? Here’s everything you need to know about how and where to set up your new wired floodlight camera.
What is a floodlight camera?
A floodlight camera is a security camera with a built-in bright light, offering a wider field of illumination compared to traditional spotlights. They are used to illuminate expansive areas like yards, porches, and driveways. The name comes from the idea of “flooding” an area with light.
You can explore options like the all-new Arlo Wired Floodlight Camera, offering comprehensive security at a budget-friendly price. With 2000 lumens of brightness and daylight color temperature, it eliminates dark hiding spots and enhances your peace of mind. Plus, with 2K HDR video and Color Night Vision, you’ll capture every detail, day or night.
Yes, floodlight cameras are worth the investment, especially since they combine multiple security measures in a single device. This dual purpose makes them a great option for quickly enhancing your home security. Floodlight cameras offer several advantages over traditional floodlights and security cameras, including:
Enhanced Visibility at Night: Floodlight security cameras provide bright, wide illumination, effectively lighting up large areas like yards and driveways.
Cost-Effective Investment: Floodlight security cameras eliminate the need for separate devices by integrating both video recording and lighting. This makes them a more affordable solution for home security.
Double as Safety Lights: Modern floodlight security cameras are equipped with motion sensors that automatically turn the lights on when movement is detected, enhancing safety and preventing accidents.
With options like the Arlo Wired Floodlight Camera, you benefit from superior 2K video quality with HDR and Color Night Vision. Plus, the Arlo Secure subscription further enhances your floodlight security camera with features like Advanced Motion Detection, Activity Zones, and 30-Day Cloud Storage.
How much do outdoor lighting cameras cost?
The average cost of a single floodlight security camera ranges from $100 to $400. Arlo’s wired and wireless options fall within the lower to mid-range. The Arlo Wired Floodlight Camera is priced at $149.99, while the Arlo Pro 3 Wireless Floodlight Camera costs $249.99.
Both options offer comprehensive protection at competitive prices. If you’re on a budget, you can also consider outdoor cameras like the Arlo Essential Security Camera (3rd Gen), which features a motion-activated Integrated Spotlight.
Do Arlo floodlight cameras work with Smart Home devices?
Yes. All Arlo security cameras—including floodlight cameras—are compatible with Amazon Alexa, Apple Home, Google, IFTTT and Samsung SmartThings. This broad compatibility makes automating your home a seamless process.
How to install the Arlo Wired Floodlight Camera.
To install the Arlo Wired Floodlight, first choose a location with an existing junction box. Disconnect power at the circuit breaker, then remove the old floodlight. Next, install the new floodlight’s mounting bracket, connect all wires, and securely mount the floodlight. For a step-by-step visual guide, check out this tutorial video that covers the entire process:
1. Find a good installation area.
Find the best location for your Arlo Wired Floodlight security camera. Choose a spot with an existing junction box and a clear, unobstructed view of the area. The Arlo Wired Floodlight Camera offers a 160° Field of View for full corner-to-corner monitoring. For the best experience, choose a location with a strong Wi-Fi signal. Also, don’t worry about the weather. The Arlo floodlight is designed to withstand heat, cold, rain, or sun.
2. Disconnect power at the circuit breaker.
Before you begin the installation, disconnect power at the fuse box or circuit breaker to avoid electrical shock. Also, check local laws and codes before any electrical work. Depending on your area, permits or professional installation may be required by law. If you’re not comfortable with electrical work, look for a licensed electrician.
3. Install the new floodlight using the included mounting bracket.
Remove the existing fixture and mounting hardware from the junction box. Place the included mounting bracket on the junction box and carefully follow the instructions. The Arlo Wired Floodlight Camera is designed for easy installation, requiring only two screws.
4. Connect the wires from the light fixture to your camera.
Again, remember to disconnect power before performing any electrical work. With the power off, connect the wires to your new floodlight camera. The Arlo Wired Floodlight Camera requires connecting three color-coded wires: a hot wire, a neutral wire, and a ground wire. Always begin with the ground wire to ensure a safe installation.
5. Finish mounting your new floodlight camera.
Tuck all the wires into the junction box and secure the floodlight to the mounting bracket using the provided screws. While holding the mount, firmly grasp and rotate the camera and floodlights to adjust the angle for optimal coverage.
6. Configure your wired floodlight camera using the mobile app.
You can complete the setup and control your floodlight camera using your mobile device and your home’s Wi-Fi network. Simply download the Arlo app, pair your floodlight, and customize it to meet your security needs. You’ll also have access to a live video feed anytime, anywhere.
Make the bright choice with Arlo today.
Arlo floodlight cameras are an excellent choice for securing your backyard, front door, porch, or driveway. Opt for the wireless model for greater flexibility, or the new Arlo Wired Floodlight Camera for a more cost-effective solution. Either way, you can ensure that you, your loved ones, and your home will be safer than ever.
