4. Get a good plunger before you need it.
A plunger might not be on your shopping list, but trust us — it’s better to have one and not need it than to need one and not have it. A simple, inexpensive plunger can help prevent disasters, especially in upper-floor apartments. In case of a clogged toilet, it can save you from a major water leak.
5. Protect your home from threats with a smart alarm system.
Speaking of water leaks, investing in a smart alarm system is a great idea for new renters. Not every threat can be caught on video, so a multi-threat system like the Arlo Home Security System provides added protection — and extra peace of mind. The included All-in-One Sensors can detect eight different threats, including open doors and windows, water leaks, temperature changes, motion, and more.
24/7 Professional Monitoring is worth it. However, if you’re on a budget, you can start by self-monitoring your security system and switch to professional monitoring later.
6. Invest in a good mattress.
Sleep is essential for your body and mind to repair and function at their best. Of all the things you can save on, a mattress should not be one of them. Invest in a high-quality mattress from the start and forget about it for the next 10 years or so. Good mattresses tend to last a decade and often come with excellent warranties. In the long run, both your wallet and your back will appreciate it.
7. Build a 3-month emergency fund.
Living alone comes with the unexpected. It’s a good idea to build an emergency fund that covers 3 to 6 months of expenses. This might take some time, especially if you’re on a budget. So, take it slow and aim to save a little each month.
8. Don’t forget the cleaning supplies and toiletries.
Your daily routine will change, and finding time to go shopping may become difficult. However, don’t forget to buy cleaning supplies and toiletries. Essential cleaning supplies include all-purpose cleaner, sponges, trash bags, and dish soap. Toiletries should include soap, shampoo, and toothpaste. Also, be sure to stock up on extra paper towels and toilet paper. (Since, you know, there won’t be anyone else around to help when you run out.)
9. Install a reliable smoke/carbon monoxide alarm.
Make sure to install smoke and carbon monoxide alarms in your new home. You’ll feel more at ease knowing you’re protected from fires, especially when living alone. Also, remember to properly maintain your smoke detectors.
Consider pairing them with a smart alarm system like the Arlo Home Security System. With an Arlo Secure subscription, it can listen for fire and smoke alarms and send a notification to your phone. This way, you’ll be able to stay informed and notify authorities, even when you’re not at home.
10. Stay social and avoid isolating.
Living solo gives you the opportunity to enjoy your own company, but it can sometimes feel lonely. Staying connected with friends and family is important, especially when living alone. If you’re moving to a new city, joining clubs or groups can give you the opportunity to meet new people. And always remember: the people you love are always just a phone call away.
